RX-2: Tonearm fails to lift sufficiently
tony0000
Posts 3
tony0000 Posted: Mon, Mar 21 2016 3:05 AM
I have an RX-2 turntable.  When the tonearm reaches the end of the record, it returns to the original position.  The tonearm, however, fails to lift sufficiently and scratches part of the record.  (Annoying!!!)  This occurs even with a flat record.  The cueing also seem to lift insufficiently.  Perhaps the issues are related.  Any ideas/ suggestions/ thoughts?
I'm new to this forum.  Thanks for any response.
Tony
Charles J Candiano
Valparaiso, IN
Posts 2
Your cueing height adjustment may be set too low.  DO NOT play another record until you identify the problem!  You could damage the stylus or cantilever!  This MAY be an easy fix.  Near the base of the tonearm, in front of the pivot, you find a brown plastic plate with a small screw sticking straight up about 1/16".  Turn the screw clockwise to raise the arm's cueing height.  Hope this helps.
Beogram 4002 (1974)
Beogram 4004 (1976)
Beogram RX  (2010)
Beovox 150's
tony0000
Posts 3
tony0000 replied on Mon, Oct 17 2016 4:35 PM
Thank you for your suggestion!  I'll give it a try.
Søren Mexico
Mexico City
Posts 6,411
Check that the mechanism lifting the tonearm is moving up and down sufficiently to lift and lower the tonearm
Page 1 of 1 (4 items) | RSS
