I have just acquired a s/h Beolab 3500 (Type 1602).
It appears to work properly when ML connected to my BV10 and respond to commands
from either Beo4 or Beolink 1000.
Should it be possible to control the volume directly on the BL3500? If so how, please?
Thank you.
I believe the only way is through the remote
Thank you
I was coming to that conclusion
