After moving to my new flat, one of my Penta 2 Loudpspeakers, which are hooked to a beosound 2300 with fully wired MK2 cables (pretty thick and the displays work), doesn´t produce sound. The Volume level in the displays is in the "muted" state. I removed the Connector cover on the base of the Amplifiert unit but wasn´t able to locate a missing pin or whatever could cause a lack of connectivity. When I pushed the connector towards the Loudspeaker, I was able to make it stay in a position, where the Loudspeaker would work. So I guess it has something to do with the female DIN connector on the Amp unit.
Any suggestions, tips or solutions to this problem ? I can upload pictures on demand :)
thanks
