Beosystem 4: how to enter PIN with Beo 4 (without Navigation button)?
This post has 9 Replies | 0 Followers
kallasr
Germany
Posts 2,562
kallasr Posted: Thu, Feb 23 2017 6:35 PM
The title says it all...
I bought a Beosystem 4 and cannot get past the pincode Startup Screen, because GO button does not work.
I have an older Version of Beo 4 (DTV/V.MEM/A.MEM), no Back or Play, just Stop and Exit Buttons.
The Center of the Joystick should be ENTER (or similar).
What button on my Beo 4 can be used?
Or do I Need to get a Beo 4 NAVI or a Beoremote One?
Ralf
Opman
Wilmslow, Cheshire
Posts 443
Opman replied on Thu, Feb 23 2017 10:01 PM
Try using the PLAY button instead.
Regards
Opman
kallasr
Germany
Posts 2,562
kallasr replied on Thu, Feb 23 2017 11:45 PM
Thanks. But no Play button on the renite.
I will check if I can add it via LIST.
kallasr
Germany
Posts 2,562
kallasr replied on Fri, Feb 24 2017 6:13 AM
No PLAY button available.
Langleyav
Windsor UK
Posts 226
Langleyav replied on Fri, Feb 24 2017 8:34 AM
SELECT is the play button on the Beo4, it is in the middle of the arrow buttons
Ron
kallasr
Germany
Posts 2,562
kallasr replied on Fri, Feb 24 2017 10:34 AM
Unfortunately it does not work...
Weebyx
Denmark
Posts 1,213
Weebyx replied on Fri, Feb 24 2017 10:42 AM
kallasr:
You were part of another thread with a 7-55 with the same issue, where the solution(most likely) was to get a Navi version, it most likely will not work until you get the Navi Beo4.
/Weebyx
Millemissen
Flensborg, Denmark
Posts 14,680
Unfortunately the original poster in that thread never returned to inform us, if any of the suggested solutions had worked ;-(
I'd say - get a Beo4/navi....and remember to set it to Mode1.
kallasr
Germany
Posts 2,562
kallasr replied on Fri, Feb 24 2017 1:19 PM
I just bought a navi Beo 4 and will update this thread and the other one as well (could not find it yesterday). The remote will arrive next week.
Thanks for your help!
Ralf
kallasr
Germany
Posts 2,562
kallasr replied on Mon, Feb 27 2017 12:31 PM
Beo 4 with navigation button works!
Page 1 of 1 (10 items) | RSS
