Airplay no longer pairs with the Essence since iOS update. Tried reboots and according to Beo Setup I have the latest Essence software. Any tips?
I can stream Spotify from my iPhone and iPad using the BeoMusic app. I had grown accustomed to using Airplay though as most of my iTunes playlist is in ALAC format and would not play through BeoMusic. So now I am largely restricted to Spotify unless I can find an easy way to convert my ALAC tracks to a compatible hi def format for the Essence.
BeoNut since '75
jameseri: I can stream Spotify from my iPhone and iPad using the BeoMusic app. I had grown accustomed to using Airplay though as most of my iTunes playlist is in ALAC format and would not play through BeoMusic. So now I am largely restricted to Spotify unless I can find an easy way to convert my ALAC tracks to a compatible hi def format for the Essence.
Wait, what? ALAC does not play? 😑
