Create a Speakers Group that consists of only the BeoLink amp and the in-wall speakers.
Choose this, if only the speaker/the in-Wall speakers should be used.
Make another Speakers Group, that includes both the speakers of the V1 and the amp/in-wall speakers, if he want sound from both.
All controlling (including volume level) - of course - will have to be made via the V1.
Limited solution - but certainly a low-cost solution.
Millemissen:Create a Speakers Group that consists of only the BeoLink amp and the in-wall speakers. Choose this, if only the speaker/the in-Wall speakers should be used. Make another Speakers Group, that includes both the speakers of the V1 and the amp/in-wall speakers, if he want sound from both. All controlling (including volume level) - of course - will have to be made via the V1. Limited solution - but certainly a low-cost solution. MM There is a tv - and there is a BV.
jans: Millemissen: Create a Speakers Group that consists of only the BeoLink amp and the in-wall speakers. Choose this, if only the speaker/the in-Wall speakers should be used. Make another Speakers Group, that includes both the speakers of the V1 and the amp/in-wall speakers, if he want sound from both. All controlling (including volume level) - of course - will have to be made via the V1. Limited solution - but certainly a low-cost solution. MM There is a tv - and there is a BV. MM Would I still be able to use the infra-red eye for volume up/volume down? John
John
Theoretically it should work fine to use the IR-eye volume buttons because they only function at your passive.
Don't forget to add 'line' for speaker type in the speaker connector on your V1 menu. So that the V1's volume control is not used anymore on the assigned power link outlets and you get a real line-out.
I do not know if your passive goes also to standby if you set the V1 to standby, but I presume it will using the correct cable.
"Believe nothing you read and only half of what you see, let your ears tell you the truth."
As Chris writes: if you want to use the BeoLink Passive with the ir-eye (and local volume control), you will have to set the V1 output (the PL/Speaker Group) to line.
But do rember, that you will have to start the playback (including choosing the Speaker Group) via the V1.
My suggestion was to use the BL Passive solely as an amp - in order to simplify the control of the setup.
Are your V1 and the speakers in the kitchen far apart?
Chris: I do not know if your passive goes also to standby if you set the V1 to standby, but I presume it will using the correct cable.
I am pretty sure, that it won't go to standby, since it (in case of using it with the ir eye) is a seperate system.
