i am thinking about buying a B&O Horizon but should I buy something else instead for the same £2500? BV11 etc? Needs connectivity , good sound quality for Spotify etc
Beosound 8, Beotime, Beocom 4, Beo 5, Lutron Rania, MacBook 15" (Mid 2015), iPad Pro, iPhone 6S, B&O Play H3, Beolit 12, Form 2, A8 Headphones, B&O Play A1, B&O Essence
If you could get a BV 11 for the same money and you're happy with it, then why not.
I would probably go for a Horizon myself
Have you seen the Horizon ? Are you happy with the picture quality and sound?
Chris Townsend:Or an 8-40, and then get some extra speakers too!
BeoNut since '75
That £2500 does not include the stand you choose , so the budget is nearer £3000.
Beo Century ,Beoplay V1, Beocenter 6, Ex-Beolit 12, Beotime , A8. Beolit 15 , Form 2i , Beolab 2000, Beoplay A3.Beosound 1
