Hope all of you are well and safe. What I thought was a simple replacement of light bulbs for my Beomaster 3000 type 2402 turns out a different issue seems present. Replaced them all and none of them works and I'm not getting any volt measurement from the bases, just a slight measurement for the stereo signal. Any ideas what is going on and where to look?
Is the Beomaster working - apart from the missing lights?
Yes, everything is working!
Check for broken wires and their connections related the bulbs sockets
Thanks, will do, I can understand that happening (broken wire) in one or two sockets, but all of them is too much of a coincidence.
All wires and sockets good.
Mystery continues.
Any suggestions are more than welcome.
