Beogram CD7000 drawer wire
This post has 1 Reply | 0 Followers
Weebyx
Denmark
Posts 1,213
Weebyx Posted: Mon, Oct 10 2016 6:00 AM
Hi all
Has anyone successfully replicated the wire that opens and closes the cd-drawer ? I am looking into what strings are strong enough, and also thin and "not-flexible" enough :)
/Weebyx
Weebyx
Denmark
Posts 1,213
Weebyx replied on Mon, Oct 10 2016 7:08 PM
Just letting you all know :)
The wire from the glass door systems(2300/ouverture), works perfectly as substitution....
It is a bit stiffer, but nothing that has anything to say. The wire is quite easy to fix, just need to cut to length, and tie the knot the right place. Had a wire that was fine to use as template.
/Weebyx
Page 1 of 1 (2 items) | RSS
