Hi.. I'm after a MMC1 cartridge in good cosmetic condition that I can get rebuilt at some stage. It doesn't need to be working. Thanks...
Hi Lee...
Yes you're right. It would just be nice to have MMC1 on the top of the cartridge..! There seems to be plenty of 4's and 5's but obviously very few 1's.
I would also add that the real life sound difference between an MMC1 and MMC2 is pretty minimal. MMC2 were standard on some of the high end turntables, and are much more common than MMC1.
Ben
Hi Ben...
Thanks for the info... If anybody has a MMC2 cartridge that would be great...! Just being a bit of a cartridge snob..!!
Thanks again...
jay
Ben_S: I would also add that the real life sound difference between an MMC1 and MMC2 is pretty minimal. MMC2 were standard on some of the high end turntables, and are much more common than MMC1. Ben
From what I understand, an MMC1 is just a hand selected MMC2, selected as passing tighter specifications. I have an MMC2 that thankfully still works and it sounds stunning. I can sort of understand wanting the label to be MMC1, but really, other than yourself how many of your friends will even notice or know the difference between a 1 or a 5?
Eventually either or both my 2 and 4 will need rebuilt, it's just a matter of time.
Jeff
