Sound Delay with WISA
This post has 3 Replies | 2 Followers
Austin
United States
Posts 136
Austin Posted: Fri, Oct 7 2016 5:02 PM
I'm using a Playmaker with a BeoLab Transmitter 1 with my 17s. When I stream AirPlay from my iPhone, there's about a 10 second delay before the 17s turn on and play. I have other playmakers and an A9 and none of them have delay.
Any ideas how to remedy this?
Duels
England
Posts 2,553
Duels replied on Fri, Oct 7 2016 5:07 PM
Austin:
I get a similar delay between the transmitter 1 and my BL18s. I believe it takes some seconds to establish a connection.
Austin
United States
Posts 136
Austin replied on Fri, Oct 7 2016 5:19 PM
Have you ever tried updating the software of the transmitter/18s with a usb stick? I tried doing that, but not sure if it worked. Mine are really close so it can't be distance related.
zerocool143
Posts 94
How to set BeoLab Transmitter 1 to "Always on"
When a speaker connected to a source via Wireless Power Link, there is delay before the speaker is powered on and sound is coming out of the speaker.
With software 1.1 it is possible to set the BeoLab Transmitter 1 to Always on. This will decrease thedelay to only about 2 seconds.
The change can be done via Bang & Olufsen ServiceTool or a USB memory stick.
Procedure for USB memory stick:
Create a “WPLSETUP.TXT” file and add the text
  o
ALWAYS ON:TRUE   ;; will enable always ON
  o
ALWAYS ON:FALSE  ;; will disable always ON
Disconnect BeoLab Transmitter 1, wait 60 sec.insert USB memory stick and reconnect Transmitter tothe mains.
Settings are now uploaded to the BeoLab Transmitter 1, wait 10 sec before removing the USB stick again.
Disconnect BeoLab Transmitter 1, wait 60 sec. and reconnect Transmitter 1 to the mains.
WPL_DUMP.TXT file is available on the USB stick with the current settings on the BeoLab Transmitter 1, and in this file the command "ALWAYS ON:TRUE" should be visible in the text file.
Page 1 of 1 (4 items) | RSS
