Hi not sure which ones are compatible, but I would definitely think about the size of the room and where the speakers are - I added a BL2 to the same setup and it made a huge difference but because the room was small you could hear the bass coming from the left, so it and the speakers are now in a much larger room, replaced with Beovox Pentas in the smaller room - which sound great!
