Hi, help please ?
My Eclipse is about three months old. Twice in the early hours of the morning I have found the power/standby light flashing green. First time it didn't stop on its own, second time it did after about two hours. Also, there is a flashing light within the casing, at the bottom about one third in from the right hand side, Its a tiny light and not easily visible in day light, but clear in darkness. I suspect it flashes all the time.
Any ideas please ?
The TV works fine - except sometimes on startup it doesn't always display the Bang and Olufsen logo before going to SKY or whatever.
Thanks.
