External IR on BeoPlay V1
This post has 6 Replies | 0 Followers
Tassos
Athens
Posts 323
Tassos Posted: Mon, May 1 2017 11:04 AM
Hello all!
In my set up when the projection screen is down the BeoPlay V1 is right behind it and as a result I can not control it via IR remote (beo6 specifically). I also own a lintronic rt238 but I already use it to control some stbs I have in a cabinet.
Is there a way to connect an external IR receiver to V1 so I can place it at some place that the screen will not cover it?
Thank you
Anastasios
Fansastic
The Hague, The Netherlands
Posts 768
You can use the BeoRemote app instead
Tassos
Athens
Posts 323
Tassos replied on Mon, May 1 2017 5:50 PM
There are STBs that B&O has no codes for them so the "translation" is done by the rt238 which can not be controlled by the app. :-(
Fl_ip
Posts 160
Fl_ip replied on Mon, May 1 2017 8:09 PM
You could try to increase the strength of the ir signal on the Beo4 (1710)
Tassos
Athens
Posts 323
Tassos replied on Tue, May 2 2017 6:19 AM
I am using a beo6 and curretly the setting for the IR strength is maximum. :-(
kallasr
Germany
Posts 2,562
kallasr replied on Sun, May 7 2017 5:06 PM
I remember a solution from Marmitek but no details in mind. Search for 455 khz bang olufsen marmitek ir extender. I might be wrong, so don't blame me Smile
Ralf
Tassos
Athens
Posts 323
Tassos replied on Tue, May 9 2017 6:38 AM
Thank you very much for the suggestion I will look into it :-)
Page 1 of 1 (7 items) | RSS
