Beolab 4 blown fuse?
tobias_tp
Posts 2
tobias_tp Posted: Sun, Oct 30 2016 11:00 PM
Hi all
This is my first post. I have browsed the forum, but I did not find a similar thread.
I sincerely love my Beolab 4's connected to my Beosound 3000, but I am afraid I have blown a fuse or similar in one of them.
I found a used Beocenter 2300 and connected my right-side Beolab 4 to it. There came heavy, sharp crackles through the Beolab 4 and no bass. The same sounds came in earphones connected to the faulty unit. The left-side was never connected to the faulty 2300 unit. I have since disposed of the 2300 unit, but the right-side Beolab 4 has suffered damage. Reconnected to the Beosound 3000, the Beolab 4 now plays with a significantly lower volume than before, although the quality of the sound is fine. It is not a balance issue. Even with the balance shifted almost completely to the right, the left speaker plays the loudest.
Is there a fuse I can replace, or must I bring the Beolab 4 to a service center?
Thank you in advance
BeoChecker
Switzerland
Posts 148
Hi
There is no fuse.
Do you have still no Sound from the Woofer after cracking noise?
Then a defective Amplifier board is well known with Beolab4.
Otherwise check the Cables and try to switch the Speaker to left channel for testing.
BeoChecker
tobias_tp
Posts 2
tobias_tp replied on Mon, Oct 31 2016 8:29 PM
BeoChecker, thank you for your reply
When I reconnected the Beolab4 with reversed laterality as suggested. It played with the low faint dull volume for a few seconds, then bass set in, and the speaker is now functioning perfectly, even when I shift back to the original Right state.
I don't know whether there was only sound from the tweeter when the problem was present.
Problem solved although not quite identified, thank you
Beobuddy
Utrecht, The Netherlands
Posts 3,972
BeoChecker:
Hi
There is no fuse.
This would be the first time ever.
BeoChecker
Switzerland
Posts 148
You're right.
But there is no fuse which can cause the described error!
BeoChecker
Page 1 of 1 (5 items) | RSS
