Hi, plz help me connect my two BeoSound 1 in multiroom system. I'm trying to connect through AirPlay from my iPad but always plays only one speaker. Can help?
Due to AirPlay restrictions you can not join in on to an airplayed source from one NL-device on another.
Have you tried e.g. joining in, when the source is a (TuneIN-)netradio station?
Yes, TuneIn are plays on both speakers. But how i can play music from my iDevice on both speakers?
you need the BeoMusic application to do the multiroom in your devices
Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Homeoffice: M3, Beocom 2 Library: Beosound Emerge, Beocom 6000 Bedroom: M5, Essence remote Travel: Beoplay E8 2.0, Beoplay EQ, Beoplay Earset
there's a possibility to stream airplay in more than one room: connect an airport express through the line-in of one of your b&o products. works pretty well with my blc-converter (thanks again, millemissen, for the advice)
edit: just seen. i hope you have more than the two BS1´s
Wohnzimmer: BeoVision Avant 55", BeoLab 11, 12-2 und 12-3 für 5.1-Sound + appleTV 4K und Philips BluRay-Player; BeoSound 2, BeoSound 3000 (fast nur noch Deko)////Schlafzimmer: BeoEssence MkII, BeoLab 4000 + Samsung 46"-TV////Büro: BLC NL/ML, BeoSound 35, Thorens TD320MkII, Samsung 32"-TV, WesternDigital 4TB-Server////Bad: BeoLab 2000; alles CAT7 verkabelt////Küche: M5 (drahtlos) plus diverse apple-Geräte (imac, macbook, ipads, iphones, timecapsule, watch)
egges:there's a possibility to stream airplay in more than one room: connect an airport express through the line-in of one of your b&o products.
Guys, all my iTunes library in Beomusic is inactive, what wrong with me?
only the music phisically on your device i active, i.e. you´ve to download it
thanks egges, I already understood, but i still can not set up multiroom. I play music through Beomusic choose both devices in multiroom settings but nothing ... plays only one speaker
BeoNut since '75
Thanks for the answer, elephant. Yes, i have Mac and music from Mac plays on both speakers. I just thought that I would a simple way to connect two speakers in multiroom system. But not.
One may hope, that Apple - some way or another - choose to solve this problem of restriction with iOS/AirPlay.
