My Beocenter 1 ( BC1) suddenly gives a green wash picture image when playing dvd`s
Green is dominant with blu an purple also showing a little greyish white .no yellow no red colours ?
The start up screen used to be gey like blanc which now isvery light blue like aqua.
At first I thought one of the cathode of the tube was faulty . But while using television mode the picture is in balance so no green haze over the picture image.
Anyone have a clue what has happened and how to fix it ?
Is there a way to reset the BC 1 to fabric settings ?
I noticed that the television switches on and of on its own as well. First i thought that maybe the beolink was at fault due to its battery. But even with the beolink out of its batteries the Beocenter switched modes on its own ?
Does anyone have some pointers in this troubleshoot ?
