NL/ML (BLC) Converter with S8 connection hub
This post has 4 Replies | 0 Followers
badgersurf
Posts 539
badgersurf Posted: Mon, Nov 7 2016 2:11 PM
Hi All,
I have finally got my lounge ready to start putting all my equipment back into, I was originally going to use a S8 connection hub with a beogram connected to a playmaker (via RIAA), a mac mini and an olive one all wired through to a Almondo powerlink switch with the other park of the switch being a Beovison 7-32 with a BS3000. This then going to a pair of BL8000.
Instead of going this route would it be possible to use the S8 Connection hub connected to the Aux of a NL/ML converter (BLC) and then have this linked via masterlink to the BV7-32 and the BS3000?
Will this work, any suggestions / help. Will I be able to join from my Moment and V1 in the other room? Will I be able to control sources on the BV7 from the app ?
Toby
badgersurf
Posts 539
Any one have any idea?
Hiort
Sweden
Posts 2,895
Hiort replied on Wed, Nov 9 2016 8:58 AM
Hello
Your intended setup is not very clear. Will the BL8000 be on the "Masterlink side" e.g connected to the BS3000 or the BV7?
Why do you need the S8 Connection hub?
If you have Moment and a NL/ML you will be able to join sources from the Moment to e.g BV7 and vise versa.
badgersurf
Posts 539
The BL8000 are connected to the BV7-32. so on the ML side of things
The reason for thinking about using the S8 Connection hub was so I can connect a beogram (with external RIAA plugged into playmaker), also wanting to connect an Olive one and a mac mini into the Aux of the NL/ML converter.
My BV7 is having the software updated at the moment so when I get it back I will play around with the set up and see what works.
Toby
Hiort
Sweden
Posts 2,895
Hiort replied on Wed, Nov 9 2016 2:12 PM
You can also connect the Beogram / RIAA into the line in on the Moment.
I´ve done that and its works good with the auto sensing.
Page 1 of 1 (5 items) | RSS
