Beosystem 4
This post has 7 Replies | 2 Followers
ESBOSS
Posts 21
ESBOSS Posted: Tue, Oct 25 2016 12:31 AM
1. Can I use Beosystem 4 with TV resolution of 1366x768? Or it works only with Full HD TV?
2. Error On B&O official site and Google can't find manual for Beosystem 4. Somebody can help me?
jvdl
Netherlands
Posts 129
jvdl replied on Wed, Oct 26 2016 6:58 PM
https://www.bang-olufsen.com/nl/product-support/picture/beosystem-4-with-beo4
ESBOSS
Posts 21
ESBOSS replied on Wed, Oct 26 2016 7:09 PM
Not found (error to origin)
Millemissen
Flensborg, Denmark
Posts 14,680
Let us hope, that they will notice that soon.
ESBOSS
Posts 21
ESBOSS replied on Wed, Nov 2 2016 4:04 PM
Still, I bought beosistem 4.
Can someone give me file (IR-code) for control the Panasonic plasma TH-65PHD?
From the Internet unable to get this device
riverstyx
SouthWest UK
Posts 938
BS4 guide is attached - hope this helps...
Martin.
ESBOSS
Posts 21
ESBOSS replied on Thu, Nov 3 2016 12:36 PM
Thank you, but I need the file of codes Panasonic TV for download it by USB in BS4
beosoundguy04
Posts 1
Silver Member
If I am correct, you are trying to update your beosystem 4 in order to find the correct IR codes for your Panasonic Plasma TV?
If you cannot connect the beosystem 4 to your network directly, you can save the download from a computer and save it to a usb thumb drive. Then connect the drive to the usb port on the beosystem 4 and follow the instructions from the manual. It does not mean your tv will be in the new device list. Best of Luck!
Page 1 of 1 (8 items) | RSS
