beomaster 3000-2
paperbag
Posts 16
paperbag Posted: Sat, Dec 3 2016 9:26 PM
hi i have a capacitor that is 3000 uf and its reading 2872 .can anyone tell me if this is ok or needs changing thank you
riverstyx
SouthWest UK
Posts 938
paperbag:
It's not possible to say either way. Capacitance readings are often not very helpful in accessing the health of a capacitor. ESR measurements generally give a better indication but you'll need an ESR meter to measure this.
Are there any visual indications this capacitor is failing? eg, leaking, bulging etc?
What's the problem / symptoms of your BM3000-2?
Martin.
paperbag
Posts 16
paperbag replied on Sat, Dec 3 2016 10:08 PM
hi martin 2 of the capacitors have a little bulge about 8mm and the fuses keep blowing.idont no if this helps but i left it switched on over nite
Page 1 of 1 (3 items) | RSS
