Got two beolab penta mk3 hooked up with my beocenter 9500.
Got no reading on the speaker display, got the switch on the bottom of the speakers switched to audio.
Anyone any ideas wether this is correct/wrong , any sugestions how to make em work?
greetings from the netherlands.
Stevie - you're specifically going to need to connect the speakers with MK2 Powerlink cables for the displays to work.
Hopefully that's all it is.
Good luck!
Greg
Beocenter 9500, Beomaster 6500, Beolab Penta MKII, Beolab 5000, Beolab 3000, Beolab 4000 MKI, Beolab 4000 MKII, Beogram 3300, Beogram 3000, 2X Beolink 7000 RDS, 2X MCP 6500
They are used now and it is working now! Thank you!
Did that and the displays are working 😊👍🏻
