I am going to make my own powerlink cables, so do anyone out there have a hint of suitable type of cable and where for buying it, meter by meter?
Thanks in advance!
/Carlgg
Ask your Beo dealer, Sounds heavenly, or Bosscom....
I`d take the fully wired PL - 8 wires - you will find wiring diagrams on the Beotech site.
Stefan
Stefan, thanks for your good advice!
I will try that!
