In order to get acces to the pcb's of my BC1800 I schould have ro remove the 4 rubber feet from the bottom according to a German sm version and then the bottom plate should come loose; by doing this 4 nuts fell into the interior but the bottom plate is not to be removed because of numerous kind of nails (no screws). Is this a standard thing or some custom solution.
Hoping there are still vintage lovers around to help me out,
regards
Aad
Jacques
