Best DIY quality cable PWL ro Rj45
marexy
Posts 710
marexy Posted: Wed, Jan 4 2017 8:33 AM
Hi
I want to DIY cable from my BS 9000 to my BL12.3
What is best possible soud quality cable ?
it works fine with PWL MK1 ..and with FTP6
What is your suggestion?
Steve at Sounds Heavenly
The cable workshop, Leics, UK
Posts 2,165
Hi marexy,
Beolab 12.3 are superb speakers - I wouldn't risk reducing the sound quality with a DIY cable Whistle For the best results, this silver plated OFC cable will out-perform standard Powerlink and FTP cables:-
http://soundsheavenly.com/powerlink-8-pin-din-connection/21-bespoke-high-end-powerlink-compatible-cable-wired-for-single-channel-audio-only-ultra-high-performance.html
A short RJ45 adapter at the speaker end of the cable will convert this to RJ45 without any signal loss (this gives better results than fitting an RJ45 plug directly to the cable, due to the cable profile):-
http://soundsheavenly.com/bang-olufsen/30-rj45-to-powerlink-compatible-clip-on-adapter-convert-new-2013-ethernet-powerlink-to-traditional-8-pin-din-powerlink.html
Kind regards, Steve.
Steve.
www.soundsheavenly.com
Page 1 of 1 (2 items) | RSS
