Hi everyone.
I’ve been looking high and low for a set of belts for a Beocord 2200. And every time something comes up, it’s always for the BeoCENTER 2200. Anyone know where I can get a set of belts of decent quality?
I purchased a MINT beocentre 2200 last night and after getting it home and setting it up I played a few lp's. I then played a cassette tape but after trying to play a second cassette tape the function is no longer working.
The tape light will light up but it is like the tape mechanism does not want to work?
Bit stuck now.I have seen on this forum that sometimes the belts can go, and that Dillen can supply them but i dont know if that is the problem.
FaceTime
As David says: Dillen here in the forum is the man when it comes for rubber things. He has the right belts for everything.
Sounds great. Can’t figure out how I contact Dillen directly, it seems. How do I do that?
I'm right here.This belt set is currently being revised. It will be in the webshop when ready.
Hi there!
Cool! And it’s for the BeoCORD 2200, not the BeoCENTER 2200, right?
/ Bo
Right!
Bo Xamuel:the BeoCORD 2200
Great tape deck by the way. I was istening to mine yesterday and I'm amazed how good it sounds.
matador43: Bo Xamuel:the BeoCORD 2200 Great tape deck by the way. I was istening to mine yesterday and I'm amazed how good it sounds.
Yes. I think it’s a very god tape deck. Must be the high quality circuitry combined with those ferrite heads, or something.
Hi, again. It just dawned on me here, that I don’t know what webshop you’re talking about? What’s the name of your shop?
Not my shop but many of my parts are sold there.
www.beoparts-shop.com
Ah, cool. I know it then. Thanks. Looking very much forward for the belts to arrive 👍🏻
