Hi all. I have just purchased a beolink 1000 remote control from Ebay, but it has no user instructions with it and they don't appear to be available on the Beoworld site. Can anyone help please?
What's the problem?
Usually every set, that can be controlled by a remote has the instructions in its user manual.
Chris
The manual is available on Beoworld. Choose products in the top menu on the Front page. Choose user/service manuals in the upper right corner.
You got to choose accessories / Handheld Remote controllers /Beolink 1000
Hope this will help you
The manual is here
There are however a number of functions not mentioned!!
Peter
Thanks all. Found what I needed.
