Hello Everyone,
after having spent the day on this amazing Forum, I've learned a lot, but still am lacking a real solution for my audio- problem.
I'm using the Penta MkI with a regular speaker cable and an 2 Pin adapter at the passive speaker's output on the Beocenter 9500's side. The function of the Display plays no big role for me. The sound is pretty good.
At switching off the beocenter before the speakers, there is a loud& humming sound which gradually decreases to silent within a minute.
I ve gotten used to it so far, but perhaps there is a better solution to this unecessary noise?
Is it better to use the Powerlink to Speakerlink with an adaptor cable? The B&O part 6275896 seems not to be available? Or are the current cables a problem?
Any suggestions? Thank you in advance!
