I can see that B&O has no solution for a flat wall mount, they only have with turn, of course I could also use that, but to expensive when I only need flat to the wall. I also found one at STBbrackets but almost same price as the original B&O. Is there no other solution to mount this TV flat to the wall?
I'm not aware of any other mounting solution at the moment.
The problem with 'close to wall' mounts is always how to access the cable connections. Some manufacturers will put HDMI sockets etc where they can be accessed from the sides or bottom of the TV when it is mounted in this manner, but with the sheer number of connections on a BeoVision this is just not possible.
So as well as providing some scope for adjustment, the hinged wall bracket also allows for easy access to the connection panels on the rear, otherwise you would likely struggle to support the television whilst connecting everything.
Martin.
