Beosound moment bluetooth
This post has 10 Replies | 0 Followers
eprokos
Posts 55
eprokos Posted: Tue, Jan 17 2017 12:55 PM
I have a samsung tv with bluetooth 3.0 and I am wondering if it can connect throught bluetooth to the beosound moment?
I have beolab 18 and thinking of purchasing moment so I can also use them as tv speakers
thank you
mbolo01
Louannec - France
Posts 2,035
mbolo01 replied on Tue, Jan 17 2017 3:17 PM
Hi - do you mean that you want to stream music from your TV to the Moment leveraging BT? I guess yes reading your post, and in this case you may expect some delays and gaps between image and sound, specially if you connect the BL 18 wireless
Hiort
Sweden
Posts 2,895
Hiort replied on Tue, Jan 17 2017 3:21 PM
I´m quite sure that you will get an unacceptable delay that way.
mbolo01
Louannec - France
Posts 2,035
mbolo01 replied on Tue, Jan 17 2017 6:07 PM
Even through the BS Moment Line In delay is unacceptable.....
eprokos
Posts 55
eprokos replied on Tue, Jan 17 2017 7:20 PM
really? even through the line in? wow!!
what if I connect the speaker over cable with the beolabs?
eprokos
Posts 55
eprokos
Posts 55
eprokos replied on Tue, Jan 17 2017 7:22 PM
I mean the moment with the beolabs over cable
Norwin
Frankfurt
Posts 57
Norwin replied on Tue, Jan 17 2017 7:46 PM
I actually have my Beosound Moment (and wireless Beolab 18s) connected through Bluetooth to my Samsung UE48JU6580 LED. WiFi Network Delay in Beosound Moment configured at lowest which is 100. In my TV I have switched audio delay in sound section, additional settings to 150. I am quite happy with this setup and use this a lot when watching movies. This setup cannot use both TV speakers and the Beosound Moment same time. Its either one or the other. Only thing left is that I am missing a center speaker and waiting for B&O to put one on the market which I do like from a design standpoint (or an affordable TV with latest technology) In the meantime I accept its not perfect yet but do not experience synchronization delays and is usable for me.
Btw... I am using the Bang Olufsen Android Beta app to remotely control the volume. Works fine as well.
Regards,
Norwin
Beosound Halo, Beosound Core 2x, Beosound 1, Beosound M3 3x, Beolab 18, 19, 12-1, 4000, Beoplay H7, A1, Almando Multiplay Surround Switch
mbolo01
Louannec - France
Posts 2,035
mbolo01 replied on Tue, Jan 17 2017 8:09 PM
Norwin:
Norwin: My understanding is that the above setting is for Beolink synchronisation delay, in a multiroom environment for example, and not to manage BT delays.
If the TV has an audio delay parameter, then this is the setting that address effectively the image / sound synchronization when remote speakers are used, so could be an opportunity for eprokos if his TV has the option too.
Norwin
Frankfurt
Posts 57
Norwin replied on Tue, Jan 17 2017 8:29 PM
Thanks for the info Mbolo. Might help later when I buy multiroom products for my kitchen and bedroom.
Regards,
Norwin
eprokos
Posts 55
eprokos replied on Tue, Jan 17 2017 9:59 PM
Many thanks!!
so i will order it straight away
cause samsung couldnt verify that and my local b&o dealer said it wouldnt work 99%!!
Page 1 of 1 (11 items) | RSS
