Current b and o Products
beosound 5 encore, beolabs 6000, beogram 4500, playmaker mk1
Hi applemac1,
Do both speakers turn off, or is just one speaker affected please? If both speakers go off together, this would imply the cable nearest to the Encore could be at fault. If only the speaker nearest the Encore goes off then it is likely to be a speaker fault. If only the farthest speaker goes off then it could be the cable to that speaker, or the speaker.
Swapping over the speakers should help you to diagnose the issue. Changing the cables can be an easy way to resolve many problems like this, I stock these cables in a wide choice of lengths:-
http://soundsheavenly.com/powerlink-8-pin-din-connection/20-powerlink-mk-3-compatible-8-pin-din-cable-with-4-cores-wired-low-profile-cable.html
Kind regards, Steve.
Steve.
www.soundsheavenly.com
