Beomaster 900 M vs. Beogram 1000 VF
This post has 5 Replies | 0 Followers
Viking4
Posts 8
Viking4 Posted: Sat, Jan 14 2017 7:22 PM
Hey everyone... I am new here, and I dont know if this question has ever been aksed here..but feel free to tell me so.  Ok, so my question: I own a Beogram 1000VF (with a built-in preamplifier) and & a Beomaster 900 M with a pair of Beovox S30. Great set, but
I get a very fainted sound while playing my Beogram with the Beomaster. I have to turn it very loud and then I hear some music with a lot of hiss. I'm thinking of opening up the Beomaster and clean it with some WD40 .
Does anyone know about this problem and have a solution? Or any advice would be very welcome!
Hope to hear someone.
Somedays I need the music & some days I need the lyrics!
Peter
Earsdon
Posts 11,991
Peter replied on Sat, Jan 14 2017 8:35 PM
Are you sure the pre-amp is there? There is a slot under the 1000 if I remember correctly and the amplifier slides out. If it is there, try the gram into the tape input and see if it works. Without the pre-amp, the sound will be very quiet and lacking in bass.
Peter
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Sat, Jan 14 2017 8:46 PM
And keep the WD40 in the garage.
It will do NO good in any stereo.
Viking4
Posts 8
Viking4 replied on Sat, Jan 14 2017 9:18 PM
Hey Peter,
Thx for your reply! I'm gonna look into that. I bought it from the first owner, and it played perfect. But It could be a problem with the preamp or the Beomaster connection. I'll let you know if figured out some more.
Viking4
Posts 8
Viking4 replied on Sat, Jan 14 2017 9:20 PM
Thx. Martin...I'll put that away, I heard Deoxit is a better choice.
Viking4
Posts 8
Viking4 replied on Sun, Jan 15 2017 9:19 PM
Hey Peter, I took an inside look at my Beosmaster, no pre-amp in there. So while I checked that out, my next step will be, cleaning by Beomaster & cables
Hope that it will fix my problem.
Page 1 of 1 (6 items) | RSS
