isnit normal that I hear some background white noise when Im listening to music?
Of course I dont hear it when the music is louder, but it can be clearly heard when I play some relaxing music before sleep. I have an A9 too, which also has this, but far less noticable.
Thanks and sorry for my english
I am experiencing a similar issue, it is easily noticeable, i.e. loud. It sounds like an incorrect tuned FM radio, even if I stop the music. If I switch the A6 on and off it stops and usually doesn't re-occur, only happens if I switch the device on after bit of a break, i.e. in the morning.
Happens with Spotify Connect but also with Airplay
Anybody else?
i've no noticable white noise at all with my devices
Wohnzimmer: BeoVision Avant 55", BeoLab 11, 12-2 und 12-3 für 5.1-Sound + appleTV 4K und Philips BluRay-Player; BeoSound 2, BeoSound 3000 (fast nur noch Deko)////Schlafzimmer: BeoEssence MkII, BeoLab 4000 + Samsung 46"-TV////Büro: BLC NL/ML, BeoSound 35, Thorens TD320MkII, Samsung 32"-TV, WesternDigital 4TB-Server////Bad: BeoLab 2000; alles CAT7 verkabelt////Küche: M5 (drahtlos) plus diverse apple-Geräte (imac, macbook, ipads, iphones, timecapsule, watch)
egges:i've no noticable white noise at all with my devices
I may not use the term white noise correct, its very much noticeable, maybe 30% off the volume of the music.
My essence on same network doesnt do it.
I dont have issues with drops,or so, its also not something that I have from day 1, it happens since maybe 6 or 8 weeks.I am guessing a software glitch, the logs within the beomusic app dont show anything
mine is not that loud, but still annoying.
I have it from day 1.
