Hi
How can you tell if it has a blue ray player, would like to know before I buy a disc.. only to find it won't play.
bv7 40 type 9443 have been told it's a mk4, but unsure states on menu 3D panel etc
rgds
Beovision 7 40 mk 5 ,beovision 6x3, beosound 3000, beogram 3300 , 2 x lc2, 2 x beocom 1401, beocom 6000 x 2, 5 x beo4,
, 4 x beolab 4's, form 2, h2, a2,a1 and a beolab 2 😀😀
If there is a drive in the bottom, then it is likely a Blu-Ray player. It could have also been retrofitted by the owner. I had one installed into my MK III when I owned it.
