I just added a Beosound Moment to my install.
I am trying to get familiar with it, but I have a few question for which I didn't have the information :
Is it possible to look for specific songs on Deezer with it or can I only browse and play my favorites ?
Also, is this something that will change in the next version of the firmware which is still in Beta at the moment ?
Another question : can I add directly other speakers I have to what I am actually listening on the beosound directly from the jukebox, or do I need to use the Beomusic App ?
My goal was to get rid of the Beomusic App, but it seems we still need to use it a lot from what I see :(
Thank you for your feedback.
Beolab 1, Beovision 7-32, Beosound Moment, Beolab 18, Beolab 19, Beoplay A6 Grey, Beoplay A6 Black, Beolit 15, Beoplay H7, Beosound Essence mkII waiting for speakers :)
Hi chguillarme,
To search on Deezer from the JukeBox, double-tap on "Discover", version 2.x beta has a dedicated screen for searches, including DLNA collection search.
To search radios, double tap on "Radio"
To add Multiroom speakers you have to use the BeoMusic app, doing it from the JukeBox is not yet an option in 2.x
Look for "BeoSound Moment Overview and Features" in Youtube.
cheers
Merci ;)
chguillarme:Merci ;) Beolab 1, Beovision 7-32, Beosound Essence MKII, Beolab 18, Beolab 19, Beoplay A6 Grey, Beoplay A6 Black, Beolit 15, Beoplay H7
