I have a similar problem with one of my LC1’s.
Works manually, but not with the remote.
Faulty ir-receiver, I guess.
Probably easier to repair on a LC2 than on a LC1 - assuming you can get the parts needed.....from another LC2.
Ir can be fixed on LC2, no problem. Touch etc.
Indeed a LC2 is easier to acces than LC1.
@ BeoGreg
There are plenty of repair guides around. These Light Controllers can like any old school B&O gear almost always be repaired.
Where did all these greatl accessories go by the way?
It's usually down to dying electrolytic caps,- once replaced the receiver will be back in business.
