I am keeping my BeoCenter 1 for the the time being, and am trying to connect it to the VX7000, and to my PC. The BeoCenter 1 has two scarts, and the TV only works if i stick the scart from my Denver set top in the right one and set the TV to V-tape. There desn't seem to be any way to get the Denver to address the TV-setting. Radio and DVD work perfectly. I tried to ron the signal through the VX, as described in the manual, and it makes no difference whatsoever, so to use the VCR, I have to disconnect the scart from the right contact.
I just noticed that the reception gets shaky when I run the antenna signal through the VX.
My second project is to try and get the VCR to feed the signal into the Happage Colossus card in my PC.
Any ideas, anyone?
