Beogram 1800 - Tonearm swings over but doesn't lower
This post has 0 Replies | 0 Followers
dbxdx5
New Jersey
Posts 65
dbxdx5 Posted: Tue, Mar 7 2017 8:55 PM
This is the 1984-1986 model. When I press Play, the tonearm swings over the record but doesn't lower. A second or two later, the platter stops spinning. I followed the procedure in the service manual for checking the raising and lowering of the arm, and the distance between H and I was 1mm, as specified. I could use some direction as to where to investigate next. Thanks.
Page 1 of 1 (1 items) | RSS
