I have two Beovisions in my house but still no soundsystem från BO. But now i have deciderad to buy a second hand stereo for the living from from BO.
My preferenser are
good second hand value
a design icon
ok sound
i will use my iPad for to play Spotify mainly
what would you recommend?
BeoSound 3200.
Small, compact, great DAC, stylish, classic, reasonably priced, AUX port so you can connect your iPad.
Lee
Beosound 3200
Beosound 3000
Beosound 9000
Beosound 5 (can be controlled from iPad with additional MLGW, maybe with BLGW, too)
Beovision 10 but no external speakers connected. I need speakers for the stereo.
David9999: i will use my iPad for to play Spotify mainly what would you recommend?
Connecting a ChromeCast Audio to one of the audio-inputs of the tv.
If you need 'more ok sound', connect speakers to the BV10.
