I have a Beocenter 7700 which I have owned just over a year and been very pleased with.In the last month I have had trouble with it,in standby mode after half an hour it switches itself on with the P mode and you cannot get it to switch to anything else.Likewise when it is playing radio,tape after half an hour it will switch to P mode and you cant switch it to anything else.In both cases the only way to reset it is to switch it off at the mains and on again.I have checked the Timer modes and its not that,anyone got any ideas?
Check the processor reset circuit.Replace filter capacitors.
