My BM 2400 is making what sounds like feedback/static and it's very loud on the radio setting (phone and tape channels working fine) and is having a hard time finding a station (though I've got a number of strong FM stations close by), when I do it's very faint and staticy, I've got the regular rabbit ears with two prong connector (rabbit ears and connector are good) and for a hoot I tried the coaxial and got the same noise, I'm not sure what the issue is, any suggestions out there?
Would love to save it, but no radio is a deal breaker for me. If it's something like changing caps, I have novice soldering skills and would feel comfortable going at it, if it's something more complex I might need to put the old girl down.
All the caps are now replaced and the radio sounds awesome! However the "Tape" does not work at all, not even a light on the console just a faint "pop" when I touch it, and the "Phono" works but is washed out - though I've only been able to playback my tape deck through the phono jack since I do not have a turntable at the moment, so I wonder if that's why it's washed out?
I'm looking for some ideas of how to go about trouble shooting to get my Tape back an Phono sounding crisp.
https://youtu.be/Nvkn_u0HFLc
https
Dear Sir,
I read your post with extreme interest and hope , since I have an old Beomaster 2400 , which is lying non functional since several years.
I have basic technical skills. Can you please guide me how you repaired your Radio & from where did you get the information and componenets.
Thanks a lot in advance
