4500 display mounth which 2 sided tape to mounth
dolle_dries
Posts 4
dolle_dries Posted: Tue, Apr 25 2017 10:34 AM
Displays 4500 system will go loose.. off all the displays
Which 2 sided tape to use mouth ?
GregKo
NYC
Posts 25
GregKo replied on Thu, Apr 27 2017 5:02 PM
The absolute best product that I've found and used with much success is servo tape.  It's literally used for mounting servos in remote control vehicles.  Any online or retail hobby shop carries it.  It's much thinner than most double sided tape and is about 10 times as sticky and basically a permanent solution.
I used it on a couple of beocenter 9500s that I restored and it works perfectly.
Trust me on this one!
Greg
Beocenter 9500, Beomaster 6500, Beolab Penta MKII, Beolab 5000, Beolab 3000, Beolab 4000 MKI, Beolab 4000 MKII, Beogram 3300, Beogram 3000, 2X Beolink 7000 RDS, 2X MCP 6500
Johan
Bolsward, NL
Posts 450
Johan replied on Thu, Apr 27 2017 7:04 PM
Hi Dolle Dries,
I have used transparant 3M VHB tape successfully for this. VHB stands for Very High Bonding and that's no lie. It is available in various thicknesses and widths. Not cheap though Sad. If you need to do one machine, I could send you a bit I have left.
Regards, Johan
Page 1 of 1 (3 items) | RSS
