CD door problem, Beocenter 8000/9000
JanKaj
Posts 4
JanKaj Posted: Sat, Apr 22 2017 7:57 AM
Problem is that the only moves some inches/cm - sometimes a bit more.
Wires are ok. Can manually operate door by turning the spindel.
Rails cleaned and and operated manually nothing can be noted.
It makes no difference where the door is - half open/closed, fully open/closed.
Casettedoor works fine
Saint Beogrowler
Saint Paul
Posts 780
Belt?
You could try swapping the deck's door belt to the cd side and see if that changes anything. Or maybe it needs a hint of lube.
Page 1 of 1 (2 items) | RSS
