I'm looking for a working tuner board for Beocenter 9300 (Beosystem 2500 etc.) european version.Part# Part# 8001413Layout# 6142103DHas part# 8050111 on frontend metal housing.
I seem to remember it was used in either Beosystem 2300 or 2500 as well.
Is your board ruined by leaking cap's Martin?
Otherwise,it could be repaired.
I've come across several of these boards where the digital to analogue control interface chip has failed-(IC3 LC7218)
Often the chip appears to have overheated.It's a SMD device,but replaceable with patience and care.
Yes indeed,the same board is employed in 23/2500,Ouverture and BC9300.
Regards,
Nick
Thanks Nick,No, it appears victim of lightning strike through the antenna.
Martin.
The BC9300 is an unfolded BS Ouverture.
Lost count on the number of donor Ouverture's I have.
When needed I will send a board.
