Beosound 8 won't power up..
This post has 5 Replies | 0 Followers
MediaBobNY
Greenwich Village, NYC
Posts 1,106
MediaBobNY Posted: Fri, Apr 28 2017 5:31 PM
I've acquired a beautiful but dead-as-a-doornail Beosound 8.  Has anyone else experienced this?  Was the problem something simple such as a fuse or bad connection with power plug?   Or something above my pay grade such as replacing the power supply?   And how do you open this thing up?
Thanks in advance..
leosgonewild
Helsinki, Finland
Posts 2,373
What are you connecting?
Duels
England
Posts 2,553
Duels replied on Fri, Apr 28 2017 7:55 PM
You need to have a device docked or some other source into the BS8 for it to work
Opman
Wilmslow, Cheshire
Posts 443
Opman replied on Fri, Apr 28 2017 10:39 PM
Hi
It is possible the dock connector is damaged/faulty. This would cause the BeoSound 8 to not wake up when you dock a device to it.
You could try using the aux line in (2 x phono sockets) and connect to the head phone socket of something. It may well be that te power supply is ok and the BeoSound 8 will spring into life when you play music through the aux socket.
If that is the case, you could consider connecting an Airport express and using Airplay instead of docking your device.
Opman
MediaBobNY
Posts 1,106
MediaBobNY replied on Sat, Apr 29 2017 12:27 AM
So embarrassed.  I figured the mere act of plugging it in would cause a standby light to go on.  Nope.  But the minute I connected my PC to it it sprang to life.
Thanks all!
leosgonewild
Helsinki, Finland
Posts 2,373
If you don't need the dock connector it is pretty straight forward to dismantle it and remove it. Looks so much better without.
Page 1 of 1 (6 items) | RSS
