Beovox 3000
dwwdww
Posts 2
dwwdww Posted: Wed, Apr 12 2017 5:02 AM
Where can I find replacement woofer for Beovox 3000 (non-active model)?  Also, can this be installed by me, or is professional assistance needed?
beowild
Posts 53
beowild replied on Wed, Apr 12 2017 3:11 PM
Hi and welcome to Beoworld!
Usually Beovox woofers are specially designed by B&O and ordered from different suppliers. It will be difficult to get new woofers on the free market which fit the original 100%. Howewer you can order spare woofers at a dealer even for older models (We are quite happy with 4 new CX100 woofers we bought for a reasonable price. Another possibility would be to repair the woofer, depending on the problem it has. You will find a lot of posts in our forum concerning repair, also on the archived forum.
To change a woofer in a beovox 3000 can be easily done by everybody: You just need a torx T20 driver to loosen the srews and can then swap the driver. No soldering needed because B&O used simple car-type connectors. The four Beovox 3000 i use in my office have drivers with part number 8480210 / 59277NE written on the back but i see no supplier name. By the way the drivers of the beolab 3000 are the same as for the Beovox 3000.
If you don't find a new driver just try to get a replacement speaker, some times you will find cheap examples with decent drivers but ugly fronts. Perhaps user Dillen or Leslie have a spare they don't need any more. For a "wanted" ad you have to upgrade to a silver membership.
At my opinion the Beovox / Beolab series 3000 / 4500 / 5000 are design milestones in the work of B&O and share almost the same concept as the new wall speaker system they relased this year.
Best regards
David
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Thu, Apr 13 2017 7:14 AM
There are no less than three (very) different versions of passive Beovox 3000.
You need to be more specific and - as mentioned above - upgrade membership level to place wanted ads.
Replacing is a matter of using a screwdriver and either pulling a pair of plugs or doing a bit of soldering.
Page 1 of 1 (3 items) | RSS
