Bad to use non-Bang and Olufsen battery?
Beocom4nightmare
Posts 4
Beocom4nightmare Posted: Thu, Aug 16 2012 5:10 PM
Is it bad to use a non-Bang and Olufsen battery on a Beocom 4? Someone at the store told me that they don't work. If I used a different battery, will I need to get a new battery or just get it flashed for new software?
Thank you.
Peter
Earsdon
Posts 11,991
Peter replied on Sat, Aug 18 2012 5:25 PM
If you get the same spec, I cannot see the problem. On the whole, B&O parts are not too badly priced though and it will come with the correct fixings.
Peter
Stan
Chicago-area USA
Posts 869
Stan replied on Sat, Aug 18 2012 6:11 PM
The guy at the service center told me that the beocom1 battery contains a chip which works to limit overcharging. If you buy non-B & O, make sure it has this. I think it has 3 wires rather than 2. I also believe Sanyo is the OEM for many batteries.
Stan
Page 1 of 1 (3 items) | RSS
