Which type number has the DVBT2 module for HD in the UK? Or the serial number when this and the 3 HDMI inputs were introduced. Thanks David.
david707: Which type number has the DVBT2 module for HD in the UK? Or the serial number when this and the 3 HDMI inputs were introduced. Thanks David.
You'll be looking for a UK Mk3 - Type Number 9553
For the 46" version (in case you want to "go large") the Type Number would be 9555.
Lee
9553 many thanks Lee. I might even go smaller if anything but I think the 40 will be best to replace a 32 Avant.
David
I did that - and regretted it - the sound is nothing like as good. Sold the 10 and kept the Avant.
Peter
I had external speakers including a BL2 but it seemed to lack in the presence band and no manner of fiddling corrected it. The picture was indeed far better on HD content though. The 11 is supposed to be much better. Very pretty television though - I had it on the motorised stand and it almost seemed to float in the room.
