Hi all
Does anyone have the connection diagram for the original powerlink to speakerlink adapter ?
In special, are there pulldown resistor between the line-in signal and ground ? If I connect a standard phone via line-in to a MK1 Beolab Penta, it powers on sometimes if the phone is not connected, and I suspect that it detects noise from surroundings.
/Jacob
Hi Jacob,
i don't have the diagramm, but i think a 1K / 0,25W resistor between L and Ground and another one between R and Ground should help to prevent unwanted triggering the circuit.
Ralph-Marcus
RaMaBo: Hi Jacob, i don't have the diagramm, but i think a 1K / 0,25W resistor between L and Ground and another one between R and Ground should help to prevent unwanted triggering the circuit.
Thanks, I will give it a try :)
