Dear B&O Enthusiasts,
i currently use the following Set-up: two Beolab 6000 speakers right and left, a beolab 7-4 as center, connected to a BV 7 32.
One of the speakers switches off after a couple of minutes of usage. The only way to get it back to work is to
disconnect from power, wait for some time and plug in again. Then it usually works on for some time until it "automatically" switches off again.
Does anybody have experienced something like that and could give any advise how to solve it?
Thanks a lot in advance and best regards from Leverkusen, Germany.
Jens
