I currently have a Beoplay M5, and a NAD 326 integrated amplifier. I'd like to connect the M5 to the amplifier using the "pre out". Will I damage the speaker if I do this?
The reason I want to do this is so I can have more devices connected to the speaker, and I'd like to use the equalization controls on the amplifier to reduce the M5's bass.
Thanks in advance!
ps - here is a pic of the back of my amplifier. Any help would be appreciated!
The pre-out jacks at the back are line-level and volume-controlled, so they should work just fine for connecting to the line-in of the M5.
As they are volume-controlled, just keep in mind that you have two places to control volume: both the M5 and the NAD.
— Tuomas | Bang & Olufsen | Bang & Olufsen Create
Thank you so much!
